Need a Tuned pipe for a K&B
GA
I have a RIRE K&B .45 in a Turbax fan. I have a tuned pipe it works not sure if its the right one. I have to use a silcone coupler to attach it to thee exhust adapter on the engine. Problem is the coupler brakes! Where can I get a pipe that mounts correctly, where the pipe goes over the exhsust adapter on the the engine.
ifly,
Have you called the JHH shop? We'll get you setup with what you need (562)-467-0260. It sounds like you're missing the header pipe. There is a header that is used to attach the pipe to the engine. The header is attached to the tune pipe via the silicone coupler. This also helps set your tuned pipe length which is crucial to get optimum performance.
Chris
Chris
