RE: Dave Patrick super cub
Frank, you will need 5 servos in the 70+ oz-in. range. One pull-pull on the rudder, two for ailerons, and two for elevator. The control rods and cable are furnished. You can use standard grade servos on the throttle and flaps. You will also want to use a computer radio that can mix elevator comp with use of the flaps.
