RE: engine
no. its not the conector for the starter. it is somewhere between the piston and the flywheel. is it possible that the flywheel is slipping? how do you remove the clutch and flywheel? it would be very helpful if you took some pics. also, what kind of pipe is that on your vulk? and what are the other two engines outside?
