RCU Forums - View Single Post - Dynam Super Cub
Old 10-01-2008 | 03:53 AM
MartinMu
Default RE: Dynam Super Cub
ORIGINAL: itzobi
Don't bother with anything from Dynam.
Why?
Because the quality stinks, everything about the plane will break on you.
And good luck finding the parts, the company is based out of china, and hardly anyone carries the parts, not like their of good quality anyway. The little plastic pieces that break you will never find.
They should inlcude a huge bottle of CA for you to glue everything back together after one crash. Land too hard and you will break the stock landing gear. Tug on the control arms too much, glue time! The stock props snap like twigs. The battery box is made out of wood and the door will break on you in no time, so get out some velcro or tape.
Don't listen to the suppliers, they will tell you they never had any problems.
Don't waste your money on this plane, I did, and I am still picking CA glue off my fingers trying to repair this thing.
HUGE WASTE OF MONEY!
I bought the Super Cub last week, because the words LiPo battery, brushless motor and ailerons sounded great to me. First shock came after unpacking the thing, second shock while assembling and last but not least when i went out and flew this piece. Finally when contacting the supplier for a replacement motor mount, came the end.
a. although mentioned on the packaging list, there is no wall plug charger included. Only the LiPo Balancer
b. The plastic parts are poor glued in. Most shear and needed fixing. Horrible.
c. The motor mount screws were drilled in too much and did no longer hold back the motor. I had to glued the plastic piece.
d. The tail wheel is plastic and mounted directly on the rudder. Hard landings can damage the rudder because of stress.
e. In the air the aircraft is quiet unstable. You have to be correcting all the time
f. After a while flying, i can say, that the elevator and rudder control is not precise enough.
g. Ailerons got damaged in flight while doing a right turn. Had to do an emergency landing. I discovered that the plastic part glued in the wing for attaching the aileron push rod, broke ??? In flight, crap.
h. I contacted the supplier to get replacement, the motor mount will arrive in December !!!
Good that the supplied LiPo battery is the same size as the one from my Wilga, and so i have something to use from the invested money.
Cheers
Martin
