RCU Forums - View Single Post - ModelTech magic 3d
Old 10-01-2008 | 04:56 PM
mclina's Avatar
mclina
Default RE: ModelTech magic 3d
Here's a couple of shots of the power system. The battery I stuck in for the photo is smaller than the one I plan on flying. I tested it this afternoon, and I got about 6 minutes at half throttle with the 2150 3S pack. I know that if I want to fly aggressively, I will need a larger pack.
I had to mount the motor 1.25" off the firewall to get it to balance. If I go to the larger battery, I just need to remove a spacer.
I also put on bigger tires to help it balance. The stock tires are very lightweight.
I guess I have plenty of prop clearance.
Still planning on a maiden this Friday....
ID:	1044492   Click image for larger version
ID:	1044493   Click image for larger version
ID:	1044494   Click image for larger version
