ORIGINAL: BlackS10
Has anyone used the Cline and Associates PCFS yet? By this Friday, I'll have my Venus II and OS 1.20AX. I want to put the fuel tank on the CG, but don't want to use a Perry Pump...
You should not need a pump, or a demand feed pressurized regulator with the OS 120AX unless the tank is fairly far aft of the firewall. If you do still want to do it, I recommend using the VP30 pump. It's a simpler setup than the PCFS and you don't have to worry about managing a pressurized tank system. The VP30 works better than the PCFS too.
