RCU Forums - View Single Post - Ignition
Thread: Ignition
Old 10-02-2008 | 12:01 AM
Antique's Avatar
Antique
Default RE: Ignition
Nope....Idle rpm is the same either way...With mechanical advance the starting setting is the same as with the setting EI goes to after the first flip....
One disadvantage of mechanical advance is if you forget to lower the throttle for starting..Very hard on your hand []
The advance curve for EX EXL ignition is on my website under ignition info..Tested and comfirmed by Pe Reivers..
