Ignition
Old 10-01-2008 | 07:00 PM
Default RE: Ignition
pm sent TomBat74
Old 10-01-2008 | 08:08 PM
My Feedback: (42)
Shouldn't rcexl ignition systems be auto retard rather than auto advance? We set them up at approx 30deg BTDC.
Old 10-01-2008 | 08:58 PM
Antique's Avatar
Semantics....Almost ALL ignitions are auto advance...The difference is at the beginning...C&H, RC EXL, and some others are statictimed at 28 or 30 BTDC..DA, Falkon, and some others are timed at about 2 BTDC....When starting with an engine timed at 28 the first 1 or 2 flips retard the ignition to about 4, from then on its AUTO advance until around 4000 rpm...It stays there until the rpm drops below 4000, the ignition RETARDS with rpm and will ADVANCE automatically until 4000 again...
The ignitions timed at 2 BTDC start there and ADVANCE until whatever they're made to do, probably at about 4000 like the others...They will RETARD when rpm drops below the high advance point, and automatically ADVANCE again when rpm picks up...
Years ago we didn't have the auto advance option, so some ignitions were mechanically linked to the carb shaft and ADVANCED with throttle opening...These reached full advance at WOT, not the lower rpm that today's EI ignitions do...
A Hall sensor will react only to one magnetic pole...MOST are set up to use the South pole to react to the Hall sensor with the part number on it...It can be set up to use the North pole if the sensor is turned over to the blank side, so an ignition with two magnets is using the South pole of one and the North pole of the other for some other function...
Early Reichmuth ignitions had 2 magnets...The advance function changed from the starting setting to the higher speed setting at around 1500 or 2000 rpm without a ramp, so there was an abrupt timing change, resulting in a big change in rpm just when the engine was coming down to the rpm wanted for landing...He later changed that to a more linear system, but doesn't seem to be around anymore...
There was another ignition that had a small pot to adjust for max rpm, he doesn't seem to be around anymore either...
Al Deim called his ignition Silent Spark...Worked well, he doesn't do much anymore either..They worked well, I bought lots of his capacitors when making my own fixed ignition...Ed Vollmer came out with the automatic advance part of ignition many years ago..First used by C&H, it worked very well when used in series with a fixed ignition...
Not all Chinese ignitions work well...The RC EXL is the very best...
There are a few other ignitions made and sold, but probably 98% of all manufacturers use a version of C&H and RC EXL....There is no better ignition system made....
Equal maybe, not better, just more functions...I myself like the K I S S principle, 4.8 volts..There is no SANE reason to use multiple batteries and regulators when a little 800 MA 4.8V 2 ounce battery will run a good igniton for at least 2 hours...Unless you just GOTTA follow the high tech crowd....Simple is BEST..[8D]
ALL EI systems use crankshft rpm to work...If the crank rpm doesn't advance, the igniton doesn't either...Electronics don't have ESP, they can't predict where the rpm is going...If the low speed needle is set too rich the rpm won't change very fast when the throttle is advanced, so the igniton timing lags slightly...The difference is infinitesimal, but a mechanical advance is actually faster at reacting than an electronic advance..Electronic advance follows the throttle EXACTLY, EI follows crank rpm..The tail is wagging the dog...
Old 10-01-2008 | 09:50 PM
RC Ignition, Is it possibe to get lower idle RPM,s with a mechanical advance over a auto advance? Kinda like the old outboard engines....lots of retard on spark in relation to throttle movement. Seemed like a lot of older RC engines worked very well with the mechanical advance. Capt,n
Old 10-02-2008 | 12:01 AM
Antique's Avatar
Nope....Idle rpm is the same either way...With mechanical advance the starting setting is the same as with the setting EI goes to after the first flip....
One disadvantage of mechanical advance is if you forget to lower the throttle for starting..Very hard on your hand []
The advance curve for EX EXL ignition is on my website under ignition info..Tested and comfirmed by Pe Reivers..
Old 10-02-2008 | 03:20 AM
  #31
My Feedback: (14)
ORIGINAL: dirtybird
Hobbycity sells an automatic advance unit for $25.
This is the ignition used for the XYZ engines. There is a thread on XYZ engines. I don't see anyone saying the ignition is bad.
I bought two of these units a while back. So far, so good.
Ed Cregger
Old 10-02-2008 | 01:28 PM
  #32
Anyone know if CH Ignitions has an email address. Per their website the only means of contact is mail or phone.
Old 10-02-2008 | 01:50 PM
  #33
Antique's Avatar
ch-ignitions.com
PM bcchi on this forum
tkg on this forum
Google CH ignitions
Google Bill Carpenter
bcchi on that other forum, the one with "giants" in the name..
Old 10-02-2008 | 02:52 PM
  #34
I'd say TKG is probably the best to catch on here, via PM. But their phone works last time I checked
Old 10-03-2008 | 12:07 PM
  #35
ORIGINAL: RC Ignition
I still have one of the Reichmuth units. It uses one magnet but has two hall devices. They were supposed to be mounted 22 degrees apart.
I never tried to use it
Old 10-28-2008 | 10:50 PM
  #36
ORIGINAL: tkg
Just bolting on a CH RCXL or anybodys RCXL will make for an engine that is way out of time and will run poorly.
The CH conversion kit is 104.95 and included a new prop hub with a retimed keyway
FFIW
CH sells the CH RCXL ignition single for 79.95 not 100. AND the timing chip and plug wire our to our specs
If a person gets the timing right with the RCXL...why should it run poorly? Thanks capt,n
Old 10-28-2008 | 11:22 PM
  #37
My Feedback: (8)
ORIGINAL: captinjohn
ORIGINAL: tkg
FFIW
TKG's point was the stock setup will NOT have the timing right, hence the new hub with the retimed keyway.
If the timing is correct it should run correctly as you assume.
Old 10-29-2008 | 09:43 AM
  #38
tkg
CH now has timing kits, with adjustable timing for the Evolution line and also the SPE line of engines.
If your ignition is working correctly and you have the timing set correctly, the engine will run fine. The engine doesn't care what name is on the ignition box just that every thing is RIGHT.
Old 10-29-2008 | 09:45 AM
  #39
MY POINT...the engine will run OK if done right! We need more competion in getting more low cost ignitions. They are not hard to install. Anyway look here for more gas engines. Capt,n http://www.modelengines.com.au/view/...7/cat/AIC.html
