RCU Forums - View Single Post - ZXX engine interference
Old 10-02-2008 | 12:45 PM
jster1963
Default RE: ZXX engine interference
Thank you so much for your reply. Now I must show my ignorance about a few things.
#4. The engine runs great. Could the glow plug still be bad? If so, could it cause a signal loss problem?
#6. How can I tell if I have a bad engine bearing? The engine seems to run fine.
My receiver is a Futaba FP-R129DP
#7. Where is my receiver crystal? There is a small aluminum looking thing in the bottom of the receiver. It has a sticker on it with writing on it. The unit seems sealed with 2 small screws in the bottom.
#8. Where is the receiver power switch? I don’t see one on the unit.
I will do the other suggestions. Thanks again……jster
