Everyone has a different method.. The best I've found is on the Airfield models site.
http://www.airfieldmodels.com/inform..._points/03.htm
http://www.airfieldmodels.com/inform..._points/05.htm
I like his method of drilling both the surface and TE together on a press for perfect alignment then cutting the bevel after the holes are done.
I use a router table for the bevel.. small Table saw or hand plane also works.
As for fitting the taper on the hinge.. I use a small square jewelers file to open up the hinge pocket. make for a nice fit with the square shank on the hinge.
This is the hinge line on my Stick using the Airfield methods
