RE: kawasaki
As i said before, i need the gaskets to repair my walbro -well i couldnt find them. i adapted a barrel tipe carb with an 11 mm hole which was on 61 FRS replica made in china ,it worked . idle at2200 and max at 6000 with a 15x8 prop . i tryed to lower the idle by fidling with the CDI angle and carb needles adjustments , well that is it 2200 not less, probably due to no pump on the carb . tank level is sensetive but throttle responce is without hesitation. i will take pix and post them. i thought barrle tipe carbs can not replace walbro but it did and well. more refinements will follow.
