RCU Forums - View Single Post - Shinden Build
Old 10-07-2008 | 11:56 AM
  #200
mjfrederick
Default RE: Shinden Build
I know Bryan has used some small wedges (like the ones used to square up a door) to angle the gear down a little bit. Also, what size tires are you using? From what I understand they're running 2.75 or 3.00 inch tires. I know the clearance is pretty close with 18" props, but you shouldn't have had any trouble with a 16.5.
