RCU Forums - View Single Post - throttle servo hardware
Old 10-07-2008 | 05:47 PM
chemie's Avatar
chemie
Default RE: throttle servo hardware
OK...while I am full of questions....this is SIG 4*40 ARF....
I read the instruction (twice) before even unpacking.
The first thing the instructions have you do is place the CA hinges and start to glue them in.
However, when I unpack, it looks like the ailerons are already assembled into the wing. I gave a "light" pull and they did not seem to pull apart but I am wondering if I need to pull them apart and then glue? or are the instructions out-of-date and they now glue them in at the factory?
Also, when I manually push and pull the aileron control rod, it will move only one way...it can push the aileron up but almost no downward movement as the rod seems to hit some wood on the wing (as if the hole the rod stick through is too small or wrong shape).
Thanks for the pointer...I know an ARF is nothing like a kit build but this is a beginner forum..
