RCU Forums - View Single Post - throttle servo hardware
Old 10-07-2008 | 06:32 PM
bruce88123
Default RE: throttle servo hardware
The reason I like the one I listed in my post #2 above is because it uses an allen wrench to tighten it. No slipping screwdrivers and damage to the plane. Smaller package sizes are available too if desired. Also remember the more "gadgets" you connect together the more possible failure points you create and it may also influence the installation. Keep it as simple as you can.
