RCU Forums - View Single Post - throttle servo hardware
Old 10-08-2008 | 05:58 AM
chemie's Avatar
chemie
Default RE: throttle servo hardware
assuming they do need to be glued, I am surprised a few drops of CA is sufficient? Why wouldntt you want to glue the one half tab firmly into place in the wing (without aileron in place) such that you could really add enough glue to the tab and inside the insert point? Then add glue to other side and assemble? Just dropping CA in the middle is sufficient?
