RE: ROBARTS ZIROLI 92" ARF ASSEMBLY
thanks for the comments.
Tail feathers
pic 1:
The vertical fin has two metal rods pre-installed that just slide into two mounts already installed inside the fuse.
pic 2:
There are two holes on the side to insert an allen wrench to tighten two hex bolts.
pic 3:
Here's the two internal vertical fin mounts.
This allows the fin and rudder to be removable.
pic 4:
Two 1" robart control horns have their bases cut off just as we did with the ailerons/flaps with holes drilled into one end for the glue.
pic 5/6:
After cutting slots into the bottom end of the rudder and internal balsa block, the two control horns were zap-a-dap'ed into place.
pic 7/8:
Two hitec HS-645 servos installed into the ends of the horizontal stab.
that's it for tonight.
