RCU Forums - View Single Post - Hyperion Helios F3A 63e and 10e build thread!!!
Old 10-09-2008 | 01:49 AM
dale691's Avatar
dale691
Default RE: Hyperion Helios F3A 63e and 10e build thread!!!
Hi guys, what servos did you use on the 63, Im intending on using standard ones, just cut the rear wood servo hole to accommodate a standard size servo and find out that the fuselage isn't wide enough and it will have to stick through the other side?
