RCU Forums - View Single Post - Sanded bevel on wrong side of ailerons... what now?
Old 05-27-2003 | 03:16 PM
FLYBOY's Avatar
FLYBOY
Default Sanded bevel on wrong side of ailerons... what now?
Cut it so you take 1/4 inch off total, then glue on a piece of 1/4 inch balsa which is large enough that you can sand the shape to the top and bottom surface. Then re-shape the leading edge so it is right. Will be as good as new. Glue the 1/4 inch on with thick CA. You will be the only one that knows there was a problem.
