Sanded bevel on wrong side of ailerons... what now?
Originally posted by rcspud
I would sand the other one to match and just have tappered trailing edges.
-Brian
IN
Sand it flat, and sand the other to be an exact match. You shouldn't be losing more than 1/4" off the back of the aileron. You won't miss it when you fly, roll rate on high rates is unbelievable with that plane.
Cut it so you take 1/4 inch off total, then glue on a piece of 1/4 inch balsa which is large enough that you can sand the shape to the top and bottom surface. Then re-shape the leading edge so it is right. Will be as good as new. Glue the 1/4 inch on with thick CA. You will be the only one that knows there was a problem.
MN
I would just complete the bevel into a nice taper to the Trailing edge. Hinge and bevel the front side, and your good to go. I have the looks of a squared of trailing edge.
What should I do now? Call Sig and get another aileron sheet or can I fix it?
