RE: Suggestion for Beginning Builders
Nope, super coverite in my opinnion, ...Sucks compaired to tex coverings. The only drawback to using tex is you should really give it a clear topcote, but that can be an advantage, say you want a flt fabric finish, coat it in clear flat fuel proof paint, same goes for any shean you want, flat to glossy. I always seem to pick semi gloss, or flat, it gives a slight shean but doesn't seem to reflect the sun so much as you fly, all you see is the color you put on it and not the mirror shine from the sun.
