If you're going to take your time building it, you might just use carpenter's glue instead of Epoxy and CA. You'll need CA for the hinges, but carpenter's glue will give you a lighter weight build overall. This is important on smaller planes. You can do the airframe with carpenter's glue and then simply buy a small bottle of thin super glue (CA) at Wal-Mart for a buck or two when you're ready to do the CA hinges.
I have an Ace Whizard 1/2A trainer kit and an Ace ME-109 1/2 Kit slated for winter projects:
http://www.acehobby.com/ace/ACE4245.htm
http://www.acehobby.com/ace/ACE4249.htm
I'm planning on building them with Thunder Tiger GP-07 engines.
These kits are available for $38.99 each or $85.99 with the TT GP-07 engine online at:
www.thundertiger4u.com
www.infinitehobbies.com
