RCU Forums - View Single Post - Small kit plane
Old 10-10-2008 | 07:55 PM
planebuilder66's Avatar
planebuilder66
My Feedback: (8)
Default RE: Small kit plane
just get what you listed, and start building, it will be a little bit before you have to get servos and a motor with covering materials and tools for that. You might want to get plain old wood glu for main assembly of the airplane, it will build just as light as CA but you can sand it and it gives you more time to position the parts and think before your stuck with what you just glued. Titebond, gorilla glue, or great planes alphletic resin. I use the GP glue the most. You'll still need epoxy for the high stress areas and for fuel proofing but I try to stray from CA as much as possible now a days.
