RCU Forums - View Single Post - 1221 and Jetcat ECU
Old 10-12-2008 | 02:47 AM
rcjets_63's Avatar
rcjets_63
Default RE: 1221 and Jetcat ECU
Hi Dave,
I'm running the 1221 Rx with my JetCat P120SE. Initially I set up the plane with throttle ATV at 100%, did the bind, then adjusted the ATV to 75% and did the teach. This is as per the instructions (version 6 ECU manual).
Later I heard here on RCU that Bob Wilcox recommended 50% (not 75%). So I adjusted the ATV down to 50% and redid the teach. No problems at all after 14 flights.
I'm not quite sure what Bandit Driver is refering to with the throttle stick at 50%.
Regards,
Jim
