Originally posted by hroachen
I run the YS91 in mine, it's exactly the same plumbing as the 110. All you need are two fuel dots. I used Hangar 9, but any brand will work.
You'll set up the tank with a clunk line and vent line as normal, and install a tee in each line near the tank. One line from each tee to a dot. The tees should be between the tank and check valve on the vent side, and between the tank and filter on the ffed side.
To fill, just pop both dots and fill. To drain, pop the vent line dot to relieve pressure then drain from the fill dot.
David
I had a YS in Fury..
I put a Tee in the line to relieve the pressure.
thanks...
