RE: Elevon issue.....
Is down travel the same for both? If so, you may have to move the right elevon servo arm one tooth on the shaft and re-center your TX trims. If the servo is not centered properly, you'll reach the end of its travel limit. Sounds like the right elevon servo is not centered properly.
