ORIGINAL: trail929
No matter which way I look at the pictures and the parts, I can't seem to get the outer shaft to fit in the ball races in the CX2 body. Just doesn't work.
what do you mean by this. when you say body are you talking about the canopy? if youare I wouldn't worry about it not fitting, unless it's rubbing (just cut the canopy then) I wouldn't worry about it. if your talking about the frame and the shaft not sliding up through the bearings then I don't know what to tell you because it should fit just like the stock one. I have the rivesud V3 and everytihg was a direct swap. pull the stock out, put the V3 in.
