RE: Crystals Failure?
One thing that I don't think was mentioned above (I might be wrong): There is no 100% sure way of knowing if a bad Rx crystal caused the crash. Although you can determine that the Rx crystal is NOW bad by swapping out another one on the same freq., it is possible it is NOW bad because you just ran the plane into a fence and damaged the crystal, not because it was bad before it crashed.
