RE: Help Covering
Remember to cut the pieces larger than you need. Use good fresh blades to trim it, and change them often. I just recovered my skyraider mach 2 with ultracote, its very easy to work with. Check out Minnflyer's videos on covering a wing. I can't remember where they are but you can pm him and he'll hook you up. I watched them twice, and now I can cover like a pro. Be sure not to use a whole lot of heat with ultracote, it is a low heat covering.
