RE: Need help with 4*60 covering.
Another trick to make things easier is to cover your triangle stock , that is bracing the elevator to the stab before gluing it down ...carefully trim the gluing surfaces after they are covered, then glue down the tri-stock. I don't know if you have the small trim iron or not. But it is VERY VERY handy for jobs like you are doing now...
