RCU Forums - View Single Post - Quick question about Gorrilla glue?
Old 10-15-2008 | 10:46 AM
MR G
Default Quick question about Gorrilla glue?
Just a quick question.
I need to know if gorrila glue is harmful to styrofoam?
I have a Creek hobbies Suhkoi 90-120 size(quite old) that was very tail heavy on it's maiden 7 years ago w/ OS120 pumped engine. I ended up cartwheeling it on landing and did some minor damage.
About three months ago I rebuilt the plane and mounted a heavier engine (Saito 180) on the front and mounted the battery way up front also.
I am now thinking it is too nose heavy and was considering moving the battery back. The problem is that there is alot of foam structure and I will need to glue a mounting plate for the battery into the foam structure.
Also if anyone knows where the best CG location be, I would be very appreciative.
Thanks in advance
MR G
