ORIGINAL: Rotor22
I haven't any other Joystick. If I go to pc system/hardware/devices, I have only a game device that is the mouse. If I uninstall it I have only the Mystery USB device.
When I enter FMS and set Joystick, I see the Joystick 1 state active but the first four bar are full, the fifth at middle and the sixth zero and no command is received. I also tried calibration but... nothing... Have you tried it with the WK-0701 seeing that You have a W36B? Do I need to set particular switch config?
Tnks, cheers. LG
Did you ever get this to work? I am having the same problem!
