RE: First time kit builder Questions
Here is what I do to start.
1 - check out the wood in the box. I take all the parts out, mark them with a Sharpie and package them up in zip lock bags based on the airplane part - Fuse, Wing, Rudder.... you get the point.
2 - Read the instruction manual and steps cover to cover, best to get to know what you are getting into.
3 - Build on a good flat surface, I use a door covered in dry wall. I pin the plans to the drywall and cover with plans with wax paper.
4 - When I build, I go step by step from the manual, but with out any glue, I test fit everything I can, pinned down to the board to make sure it all fits right, and to find any problems with the instructions, or my understanding of the instructions. I cannot tell you how many times I have glued things together only to realize that I made a mistake or used an incorrect piece of wood. Building with out the glue helps with this problem - at least for me.
5 - I like to use yellow wood glue rahter than the CAs for most applications. It has a longer working period, is cheaper and holds very well, it also cleans up and sands easier.
6 - I also like to build with my son and daughter, it takes longer, but they like it a lot.
Have fun, building can be very relaxing and rewarding when you see your plane take flight for the first of hundred and first time!
