ORIGINAL: outdoorhunting
OK.One thing I failed to ask. Do I hook the servo to the tailwheel & then use springs to the rudder? Or, do I go directly to the rudder & then to the tailwheel ? I'm thinking the later would be the way to go. Again, thanks to everybody !!!
Go direct to rudder then use springs to go to the tail wheel. This saves the servo as no shock loads when the tail wheel hits an object that deflects it.
