RCU Forums - View Single Post - Blade 400 blinking light on the receiver ?
Old 10-17-2008 | 06:46 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Blade 400 blinking light on the receiver ?
If its a spektrum system that means you had a power failure.
Usually its caused when you switch batteries or reconnect one without turning the transmitter off. If you want the blinking lights to go away turn off the transmitter each time you unplug the battery and turn it back on before you plug another one in.
