RCU Forums - View Single Post - How much power is needed ?
Old 10-17-2008 | 11:40 AM
cyclops2's Avatar
cyclops2
Default RE: How much power is needed ?
What is a F E boat ? style ?
If I use the complete 36 volt Dewalt pack and divide that into the 1200 watts, I come out with 33 amps. Which is way over 1 electrical HP even with losses. that would also keep the amp draw well under 20 C also.
20 to 30 mph maximum.
I can use the 36 volt motor from a Dewalt drill. Will check it out for rpm. If it is only 3000 rpm the 4.5" pitch gives a prop speed of 12 mph. []
