RCU Forums - View Single Post - New LEO 110 build
Old 10-18-2008 | 10:45 AM
Captin1's Avatar
Captin1
Default RE: New LEO 110 build
I did a trial fit early on of the fuel tank and it worked out pretty good
now it is time to install the lines and plumbing
I looked at the 3 aluminum fuel line pieces they sent with the kit the, the smaller two would be fine for the pressure and fill line
the last larger piece was to be the main line to the carb
It will changed for a standard brass 1/8 diameter tube I also changed the clunk to a brass one
the orginal lines were just to small to feed the carb
I also bent the pressure line and the fill line up
I will put the check valve in later
The fuel tank was designed for this plane it will hold 470 cc of fuel
and will fit into a specific spot in the former over the cg line
now all I have to do is put the blue fuel line to carb and the orange to the pressure and the green line hooked to fill line
I like using different colore lines to keep things seperated
ID:	1054192   Click image for larger version
ID:	1054193   Click image for larger version
ID:	1054194   Click image for larger version
ID:	1054195   Click image for larger version
