Coverite Fabric
It is so easy to put on , don' t need on e , instruction sheet says it all , If you use nitrate dope is easiest , 2 coats on edges of the airframe , sand lightly after . lay cloth on & dope edges to secure . now shrink it with heat iron or gun . Put on 2 coats of nitrate , & paint . leave it a few days before painting . Also can use 3 m contact cement to "stick it on" with / put 2 coats to the edges of airframe ,after dry time Iron on the coverite to frame .
