RCU Forums - View Single Post - New LEO 110 build
Old 10-19-2008 | 08:36 AM
Captin1's Avatar
Captin1
Default RE: New LEO 110 build
I installed the wing bolt today
The old carpenter phrase come into play here always measure twice and cut once or my case drill just once
I aligned the wing up measured from the tips to the back of fuselage actually I did this about five times to make sure it was correct
I used tape for marking
Than I drilled it and installed the blind nuts
I still have a few more things to do Like glue the stab on but before I do that I have to clean my bench so I can block up the tail to make sure it is square with every thing else
Than I must check out the wing saddle to make sure the wing is level
I have to install a fuel dot system
I have to install pushrods and all hardware on all the surfaces
I still have to install the header system
ID:	1054840   Click image for larger version
