RCU Forums - View Single Post - breaking 8t diffs
Old 10-19-2008 | 09:02 AM
INTEGRA's Avatar
INTEGRA
Default RE: breaking 8t diffs
ORIGINAL: mabuecker
there are aluminum inserts (I didnt know til I tore them down,was bought used as well) It feels like the rr diff and i'll check (shim planetary gears inward?). on the orings on buggy do you put the metal oring on in buggy diffs ? in my manuals it has metal orings over the rubber grommet in truggy and none in manual on the buggy ?
no u shim the Ring gear.....pending on what the mesh is doin.....and for the shim under the o-ring....are you using the HD diffs? i took that shim out after i installed the HD's....as i found that shim to Gouge a small ring into the o-rings and imo cause them to fail and leak.
