ORIGINAL: MinnFlyer
ORIGINAL: MasterAlex
ORIGINAL: saramos
Here is the best advice I can give you, and probably about the best advice anyone could give you!
www.airfieldmodels.com
Just let someone know that you're going to venture into Paul Johnsons' website. That way, if no one hears from you, in a few days they can send a search party in after you.
Second best advice I can give is, look at some of the kit build threads here on RCU and either build along with one, or start your own.
Welcome to building!!
Scott
Scott's pointed you to a goldmine of information over there at Paul's site - be warned, this is going to drain you (in a good way). Also, in case you havent' seen this [link=http://www.rcuniverse.com/forum/m_3439708/tm.htm]thread[/link], this is RCKen's masterpiece LT-40 build with a ton of information in it too. Both links are highly recommended for first time builders.
-MA
RC Ken and I started a website specifically geared toward the beginner:
http://www.gettingairborne.com/
Thanks That has some great info.
Question: When you laminate do you clamp the pieces or doesnt it matter?
