Hi,
Just ggt hold of a .15 size cessna bird dog ARTF. Hit a snag in that the standard servos are waaaayyyy too big to fit in, so have got some 2.0kg stall torque micro servos, trouble is these are too small so will have to build an adapter to fit. Is this a reasonable servo rating to go in this model? Have a look here at the actual bird:
http://www.cmldistribution.co.uk/cml...tId=0000002722
I have seen a slightly bigger (and a lot mopre expensive) servo available, however, they have the axact same ratings for everything as these smaller ones. This isnt going to be an aerobatic plane by any means and at only 45inch wing span, and weighing next to nothing, I think they should be ok??
Thanks for your help!!
Ben
