RCU Forums - View Single Post - Add-on #3 has some bugs
Old 10-20-2008 | 12:06 PM
SoCalSal
My Feedback: (16)
Default Add-on #3 has some bugs
Hi.. Just got a downloaded version of add-on CD3. The problem I'm finding is that with the true scale aircraft the AN3 bi-plane has no reaction other that to raise the sound volume of the engine when throttle is applied???? the aircraft
does not move at all. The other planes seem to be fine other than the VERY slow reaction to slow throttle settings. I have to cut the throttle and then fly a circut or two while the engine winds down on rpm.
Have you been getting any others with this same problem?? I have only the origanal AFPD CD with the add-on disk that comes with the deal plus add on # 3 from a download. I have no other downloads of planes or anything thing else. I have tried 5 times to erase all information and re-load but the AN3 bi-plane does not seem to work. The control surfaces work but like I said.give it throttle and it just sits there. All other true scale aircraft seem to work.
