RCU Forums - View Single Post - Add-on #3 has some bugs
Old 10-21-2008 | 06:43 AM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default RE: Add-on #3 has some bugs
The card should be OK. With regard to the AN3, pls check if you have the wheel brakes on? Pls check what channel is assigned to the wheel brake function and if you have assigned it to a keyboard key or a radio switch. You will need to calibrate the switch or key too.
