RCU Forums - View Single Post - Engine settings HELP!
Old 10-21-2008 | 10:37 AM
speedair
Default RE: Engine settings HELP!
Id leve the low speed where it is and just adjust the high speed according to what the engine wants. The low speed should be set at the factory. Once you have broken in the engine, you should open the throttle to full power and then adjust the needle untill you get max rpm from your engine then turn it 1/4 a turn rich.
I have had no problems at all using this method
