ORIGINAL: Top_Gunn
I have the same problem with CA, so I use the odorless stuff and it's fine. Expensive, though.
Does that mean its safe , because it does not have an order. I'm not trying to be smart or question this, but if it really is safer I will start buying it. Have they tested it? I have started to use a fan to blow the fumes from my face, I think that helps but its still in the air and if I do a lot of work with it ,the basement can get full even with the fan.
If anyone has info. on the orderless being safer, I would like to see it.
thanks
sticks
