WHY COMPROMISE!!!
Hi ya guys,Just received my Hi-torque servo from Hong Kong and fitted it to my AX10,power is awsome! But I have had to compromise the lock-to-lock on the steering[&o].I'm not that concerned with the transit time just really want to get a good lock on the car.It says in the spec it will stall 13Kg @ nearly 5V (459oz)thats good?(thats how I worked it out ,it maybe wrong)But when I used my Hi-Tec @80oz the steering was better?Why is this?
Operating Speed (4.8V no load) : 0.17sec / 60 degrees
Operating Speed (6.0V no load) : 0.13sec / 60 degrees
Stall Torque (4.8V) : (13kg/cm)
Stall Torque (6.0V) : (15kg/cm)
Temperature Range : -30 to +60 Degree C
Dead Band Width : 4ms
Operation Voltage : 3.5 - 8.4Volts
Dimension : 40.6mm*19.8mm*37.8mm
Weight : ~56g revolutionshop [X(]
Revolutionshop is the site where I ordered it from if you want to check it out.
Anyone of you crawlers help?
Regards
James.
