Hi.
My MVVS 35 is running great.
But the inside of my cowl and engine compartment get realy dirty from oil.
Its fresh unburned oil, so i guess its comming from the carb. I have checked for leaks at the head, and spark plug, and exhaust, and it is all well.
Can I install a velocity stack to prevent some of the fuel/oil spitting out of my carb ?
Will it help ?
I have found these for ZDZ motors........as they also use walbro carbs, I guess thay will fit ?
http://shop.lindinger.at/advanced_se...ansaugtrichter
Do you know is the 40/50 size will fit my wt 561
Pe, maybe you have one in stock that will work with my engine ?
