Fuel spitting out of carb
Hi.
My MVVS 35 is running great.
But the inside of my cowl and engine compartment get realy dirty from oil.
Its fresh unburned oil, so i guess its comming from the carb. I have checked for leaks at the head, and spark plug, and exhaust, and it is all well.
Can I install a velocity stack to prevent some of the fuel/oil spitting out of my carb ?
Will it help ?
I have found these for ZDZ motors........as they also use walbro carbs, I guess thay will fit ?
http://shop.lindinger.at/advanced_se...ansaugtrichter
Do you know is the 40/50 size will fit my wt 561
Pe, maybe you have one in stock that will work with my engine ?
Will it help ?
