RCU Forums - View Single Post - Festo fitting
Old 10-22-2008 | 07:41 PM
SoCalSal
My Feedback: (16)
Default Festo fitting
Hi, I'm looking for a Festo fitting. What I need is a 90 degree fitting where the threaded end is 4mm and the tubing end is 3mm. I have tried Dreamworks Model products but all they have is 3mm threaded with either 3/4 mm tube end.
I know I may have more help here than other forums as you jet folks use these fittings more than the other guys do. I'm going to replace a broken fitting on my 5 cylinder 215cc RCS 215 4 stroke. t is used for a air pulse from the crank case to the carb.
Can anyone direct me to a dealer that might have these fittings?.
Thanks for any help.
RC Showcase has none.I have already tried.
