Festo fitting
My Feedback: (16)
CA
Hi, I'm looking for a Festo fitting. What I need is a 90 degree fitting where the threaded end is 4mm and the tubing end is 3mm. I have tried Dreamworks Model products but all they have is 3mm threaded with either 3/4 mm tube end.
I know I may have more help here than other forums as you jet folks use these fittings more than the other guys do. I'm going to replace a broken fitting on my 5 cylinder 215cc RCS 215 4 stroke. t is used for a air pulse from the crank case to the carb.
Can anyone direct me to a dealer that might have these fittings?.
Thanks for any help.
RC Showcase has none.I have already tried.
My Feedback: (16)
CA
I'll check it again in the morning. I too looked at the catalog and didn't find the size I need. It may be 5mm but it sure is not 3mm. I ordered a 3mm-4mm #QSML-M-3-4 and a QMSL-m-3-3 both from the Dreamworks web-site but just my luck both were wrong for my applacation. Now 'm out some bucks and have two parts I can't use. I will have to dis-mount the engine so I can get the carb off of it (carb is mounted directly on center of back of engine) So I will do that in the morning and see if I can get a 5mm tap in the hole. If it is 4mm threade end then I will have to order it via the engine maker as it would appear to be a custom made fitting.
I'll let you know what I find out.
Thanks for your help
ORIGINAL: SoCalSal
M4 is hardly used in europe
festo has only M3 and M5.
is it this one?
this is the m5 to 4mm
My Feedback: (16)
CA
ORIGINAL: digitech
is it this one?
ORIGINAL: SoCalSal
is it this one?
My Feedback: (24)
ORIGINAL: SoCalSal
Todd
My Feedback: (16)
CA
ORIGINAL: lov2flyrc
Just call us for an RA number and you can return them for the correct size
Todd
ORIGINAL: SoCalSal
Todd
Steve
